Video encoding software Episode Pro v.6.2.1.1 is creating a problem
Hello friends
I have been using Mac OS but recently I have upgraded my system to Lion 10.7.2. after upgrading my system my video encoding software Episode Pro v.6.2.1.1 is creating a problem. each time I try to submit the workflow, it gives me the following error: "Failed: Job Crashed Unknown Error"
The screenshot of the error is attached below:
I tried to fix the issue by renaming the workflow as "untitled" and it worked but unfortunately not always. I cannot get the sequence of when it works and when it doesn’t. I also changed the priority, but the same problem occurred. I cannot understand the rhythm of when it works and when it fails.
Has anyone else encountered this problem also? If yes, were you able to fix it up.
Please help me out if you can.
Your suggestions and ideas are most welcome
Regards
Grace
