Hello Tech Experts,
After the Avisynth update to latest version I am getting this error message. I updated from old version to new version, it works to some extent. But all of a sudden I am getting this error. The video graph failed means; do I need to restart the program? Please help me resolve the error. Thanks.
Avisynth Error Message:
DirectShowSource : The video Graph failed to restart after seeking. Status = 0x80004005
points
This looks like some trouble with codecs. To fix this issue, install these codecs: ffmpeg, haali.
For a better result, this K-Lite Codec Pack will be the best.
Also, you can try another one called ffmpegsource2.
Now you can easily run application without any trouble.
If you keep seeing this error after an update, try updating your video driver. See the following list of computer and video card manufacturers:
If this doesn’t help, uninstall and reinstall the affected program. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select the affected program among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and click to delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then install the program back or install a much newer version.
