Hello all
I have been trying to convert a video to the iPad format using video converter v6 but the video wont change and it results in the following error.
The screenshot is attached below:
The message states:
Video to iPad converter
Access violation at address 009B2792 in module ‘ASPlayerlib.dll’. read of address 00000000
Any ideas how to solve this issue? I'll be really looking forward for some help from you all.
Regards
Video to iPad converter access violation
Hi Jonathon,
I have read your problem. This can be caused by various reasons such as-
i) Using a demo version of the software.
ii) Incomplete download or internal error.
iii) Unsupported format.
iv) Using old version of the software etc.
To solve this you can use the following steps-
i) Update your software.
ii) Download an advance version of the same software.
iii) Search internet for new converter.
You can use xilisoft. This is the best software in this case in my opinion.
Regards
