I have a Windows Media Encoder on a computer with 2GB RAM and i3 processor with Windows XP SP3. While trying to encode a video, it will be shown at first, but when encoding the audio to keep, the video is missing. How can I fix it?
madmax
Video is missing when encoding in Windows Media Encoder
Hi ,
Please download VLC media is no problem.
Here is a link to download to it.
The problem should be with the windows media encoder and not the audio files and video files that you are trying to play using that application, and therefore you it will better if you try other players. But if you still need to use the windows media encoder, then you will need to either reinstall it, try to fix any problem that it might be facing for instance registry problems and for that you can use the ccleaner utility which you can get for free from the internet.
Otherwise I will recommend for you some of the best video and audio players that will give you service without any trouble. And these are:
The vlc player.
MPC star.
KMplayer
All these you can download them for free from the internet.
Regards
Thompson Locker
I was really irritated because of this problem. I really don't know what to do. You are a blessing in disguise, Thompson Locker. I installed VLC Media player and all video & audio files are playing correctly. NO ERRORS. I'm lucky that I posted in this site.
