Video Player Software for Browser in Mobile Phones
Hi, i need mobile browser video player, like some built in player which runs under some browser. If someone has some software to recommend, i would be grateful for that. Â
Hi Gary,
You can try downloading Skyfire 2.0 for iPhone and Android phones. Usually, phones with S60 can play videos from browsers, they will just open your video player and play it there. But if you want to play the video within your browser, it may require some softwares likeÂ
1. Photon Browser
2. Skyfire
3. Puffin Web
4. and Skyfire VideoQ
Please do note that some of them have payments before you can use them. Personally I have the Photon browser and it is very user-friendly.Â
Hope this helped! Thanks!
I’m not sure if there is a browser that can’t play a video nowadays because that’s important especially on mobile devices. If you are using an Android phone, the pre-installed Chrome browser is already capable of playing videos if the page includes a video. If you want another browser, try UC Browser.
The latest version uses a uniquely self-developed U4 engine which enhances your connection up to 20 percent. It also has a data saving feature which compresses your data which, in turn, speeds up browsing and saving your data. It has a video feature which allows you to watch TV series and movies. Another feature that might interest you is the Facebook mode.
This feature boosts your Facebook browsing regardless of your network condition. Another browser that’s best in videos is Opera Mini. Among its cool features is the ability to download videos from the website. When it is set to extreme mode, it scans the site and informs you which files can be downloaded depending on the site. Unfortunately, this feature doesn’t work on YouTube.
