Video Problem in HP-D530 PC VGA DRIVER
I bought a HP-D530 chipset and windows XP install on it that VGA graphics, color, and videos are running and working perfectly then I decided to install windows 7 on same pc no installation and running problem but I just hit the Mediaplayer and I open a *.flv video it is running smoothly but a green strip line appear in the middle of running video.
So my question is that what is the problem with VGA driver or hardware?
VGA specification are as under:
INTEL(R) EXTREME GRAPHICS 2 REPORT
Report Date : 09/28/2011
Report Time[hr:mm:ss] : 19:08:55
Driver Version : 6.14.10.4656
Operating System : Service Pack 1 (6.1.7601)
Default Language : English
DirectX* Version : 9.0
Physical Memory : 1527 MB
Minimum Graphics Memory : 8 MB
Maximum Graphics Memory : 96 MB
Graphics Memory in Use : 8 MB
Processor : x86
Processor Speed : 2992 MHZ
Vendor ID : 8086
Device ID : 2572
Device Revision : 02
Accelerator Information
Accelerator in Use : Intel(R) 82865G Graphics Controller (Microsoft Corporation – XDDM)
Video BIOS : 3241
Current Graphics Mode : 1280 by 1024 True Color (85 Hz)
Devices Connected to the Graphics Accelerator
Active Monitors: 1
Monitor
Monitor Name : @monitor.inf,%flatron795ft%;FLATRON 795FT
Display Type : Analog
Gamma Value : 2.72
DDC2 Protocol : Supported
Maximum Image Size : Horizontal: 12.9 inches
Vertical : 9.8 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (67 Hz)
640 by 480 (72 Hz)
640 by 480 (75 Hz)
640 by 480 (85 Hz)
720 by 400 (70 Hz)
720 by 400 (88 Hz)
800 by 600 (56 Hz)
800 by 600 (60 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
800 by 600 (85 Hz)
832 by 624 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (70 Hz)
1024 by 768 (75 Hz)
1024 by 768 (85 Hz)
1024 by 768 (87 Hz)
1152 by 870 (75 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
1280 by 1024 (85 Hz)
1600 by 1200 (60 Hz)
1600 by 1200 (65 Hz)
1600 by 1200 (70 Hz)
1600 by 1200 (75 Hz)
Display Power Management Support:
Standby Mode : Supported
Suspend Mode : Supported
Active Off Mode : Supported
Other names and brands are the property of their respective owners.
Please reply in details would be greatly appreciated.
Thank you.
