Problems with my Graphic Card Resolution on playing games
Help needed. I just recently formatted my PC & installed Windows 7. Everything is great, graphics and stuff. I have installed all the games I wanted to play, these are just regular games online.
When I logged in to my usual game, the graphics is bad and its dragging. Its bluish all in all. What happened? the graphics in my PC is wonderful. Pictures are fine.
Help please.
Best Answer by adamcreed22
Answered By 0 points N/A #120227
Hi!
Yes, everything should be fine after Windows 7 installation. Windows loaded generic drivers to your PC for it to work after installation. Now, when you start running your favorite games, it might need the specific Video drivers for it to run smoothly.
Solutions:
A. Check your package and CD installers and look for the video or graphic driver/installer.
B.  If you can't find one, check the brand of your graphic card by looking at it or you can go to device manager and check the name. Download the driver for that graphics card. Usually you will find NVIDIA or AMD graphics card, depends. Just check it out, install it and you should enjoy your games after.
If problem is still showing, you might have installed the wrong version or driver for your video card.
vcards drivers can be downloaded from:
www.nvidia.com
www.amd.com
