Video Speeding issue with VideoPad editor.
Why is VideoPad video editor not speeding my videos? I have been using VideoPad video editor program for my video editing for some time now, but I always have issues with the video speeding feature of the editor. I have set up the speed using video effect and increase the speed by 200% yet the effect can not be felt on the video been played. How can I resolve this issue?
Answered By 0 points N/A #190178
There are two options that you could do to achieve the result that you wanted. First option is to save the existing file you are working on with the speed set is at 200%, just like what you have mentioned. Then try opening the file and edit the speed variations again. If in case there is a little effect after, try editing the file many times doing edit, save and re-open the file, until such time the result is way better than the first one. Another option is to uninstall and reinstall the program. Hope this freshen up the system particularly your VideoPad editor program.
