Aloha Ortiz
Posted on - 01/25/2012
I just downloaded a Nook application for my i-phone. I have a book on Adobe Digital which I purchased from Norton e-books. Can anyone please explain for me that how can I view this book on Adobe Digital through Nook application?
Viewing an e-book on Adobe Digital through Nook application
Following are few steps that might help you in this problem. Though it's not a genuine problem but still it might help you out.
First there is a list of steps that you need to perform in your computer.
Download the Adobe Digital Edition Software from here.
After installing it,run it and it will ask you to register your computer.
Connect your Nook to your PC. Remember if the ADE software is not able to recognize it then you have to close the software,connect the nook again and then open the ADE.
Authorize your Nook as you did with you computer in the ADE.
Now whenever you are going to purchase any book, follow the below steps.
When you are downloading the file, it will ask you what do you want to do with your file. Select the"Open With ADE" option. It will select the.acsm file.
ADE will now start the download and proceed it and save it into the ADE.
Now to get this book from ADE to your nook, see the nook on the left side of the pane. Drag the specific Ebook from the right pane to left pane icon of nook.Drop the book here and it will copy to your nook.
Unplug your nook from the computer after removing it from the taskbar option of safely removing it.
Now comes the part where your nook is involved. Proceed by following the steps mentioned below.
Select "My Library".
Go to "My Documents" option.
Select the "Check new Documents" option.
Now the new book that you just purchased will appear in it.
