Viewing Windows explorer animated gifs how to’s?
I am wondering how to view windows explorer animated gifs. I am using windows 7 and gifs seem not to "move" all at the same time… How can I make this work?
Good day. As far as I know Windows 7 doesn't support this type of file. In order to view it you need to have internet to view it. You could try another program also, such as GIF Viewer 3.3, it is one of the best things you can have to view your animated GIFs. Try checking this site. I promise this is a lot faster than other third party sites: http://www.gifviewer.org/.
By default Win 7 is only designed to play GIF files from any type of browsers. You may use the windows Photo Viewer and can open up the file but then again the animation would not be visible. The only possible resolution is to install a third Party application that can play such files.
Notifications
