My Vip Menu just had an application error. How do I solve this problem? It says the memory could not be written, what does it mean? If you can point me to someone who knows this that would also be great.
Vip Menu.exe – Application error
The instruction at “0X660f5ea2” referenced memory at 0X00000000”. The memory could not be written.
Avel
Vip Menu – Application Error. How to solve problem?
Hello Avery,
That could be a problem possibly because of the corrupted registry entries, and therefore to resolve it you will need to do the following:
Install CCleaner on your computer and then run it. Choose the option for fixing registry entry issues and then retry running Vip again.
If the error persists you might need to reinstall Vip.
Carl
Hello Avel,
The VIP menu error which you have mentioned it may occur because of several reasons like if any vip.exe file accidentally has been deleted or any registry file is corrupt or any file damaged by virus and more on. Anyway to resolve the problem I would suggest you to download vip.exe error fix tool. There are many sites from where you can download this software. Hope this could help.
Good luck.
