I have received this error message when I tried to install VIP Software Package Setup but it failed several times. How can I fix this problem? I need your valid suggestions. I will be really grateful to provide any solution.
Setup Failed
One or more issues caused the setup to fail. Please fix the issues and then retry setup.
VIP Software Package Setup Failed
If the VIP Software Package you are installing refers to the VIP software application or Virtual Instrument Player by AKAI Professional, you should check if your system meets the requirements. The VIP software application supports Windows 7 and Windows 8 as well as OS X 10.8 Mountain Lion or later.
The installation package already contains both the 32-bit and 64-bit standalone application including the 32-bit and 64-bit VST, 64-bit AU, and AAX plug-in format. Also, try visiting AKAI Professional Knowledge Base and see if you can find a firmware update if your program includes devices and accessories. If you still can’t install the software package, try launching the installer with administrative privileges.
To do this, right-click on the installer or setup file and select Properties. Select Compatibility tab. Under “Privilege level”, check “Run this program as an administrator” then click OK.
After this, run the installer and see if it works. If it doesn’t, contact the software developer from its website and ask for support.
