I installed Virtual Dj to play a little bit, but I had this surprise made by this error. I tried different versions but all came with same error. My sound is working fine, this is the only error that I have at this moment. Is any expert available to help me fixing this error? Maybe you can explain me how can I avoid this kind of errors?
Thanks!
VirtuaIDJ
Error in the sound driver of CoreAudio: Your soundcard is probably not connected, or the settings are incorrect.
Ok
VirtuaIDJ Error in the sound driver of CoreAudio
Since you are in Mac OS X, your soundcard should support multi-channel CoreAudio which is probably available in 5.1 and higher soundcard types. If you are not sure, try reinstalling VirtualDJ to possibly restore any damaged files. Also, make sure your operating system is supported because you are using an older version of the application.
For VirtualDJ 7.0.4, it supports Mac OS X 10.5 Leopard and 10.6 Snow Leopard. If you no longer have its installer and you still want to install the same version, you can download it again from VirtualDJ 7.0.4 for Mac. In case you want to upgrade to the latest version, you can download VirtualDJ 7.4 which supports both Mac and PC.
For Windows users, it supports Windows XP Service Pack 3 and higher. For Mac, it requires Mac OS X 10.5 Leopard and higher. For PC, you should have a multi-channel DirectX compatible audio card. For Mac, your soundcard should support CoreAudio.
