Hi there,
When I tried to open Virtual Box after the installation was done this error message box appeared on my desktop and it doesn’t want to open at all. Does anyone have any idea about this error ? What should I do to fix this error ?
Thank you !
VBoxService.exe application error
The instruction at referenced memory at “0x0041e135” referenced memory at “0x00729428”. The memory could not be “read”
Click on OK to terminate the program
Click on CANCEL to debug the program.
Virtual box error opening the program after installation
This is normally just a random error and I usually see this from time to time on my computer when shutting down. The system usually returns to normal after rebooting your PC. So to check if it is just a glitch in your system, restart your machine then try opening VirtualBox again.
If that’s a glitch then you should be able to start VirtualBox after the reboot. But if you see the error again, check if you are using the latest version. If not and you are using an old version, download and install VirtualBox 4.3.16. It supports all versions of Microsoft Windows as well as Linux and Mac OS X. You should also check if the total amount of memory of your computer can support both your operating system and the guest operating system you’ll be running in VirtualBox.
If the problem continues, try adding more RAM so the computer can support both the host and guest operating systems. Host refers to your computer’s main operating system and guest refers to the operating system you will run within VirtualBox.
