Virtual Box Mac Installation Problem AMD Processor
Hello ,
I am using oracle virtual box 4.1. And my Laptop is ASUS (AMD processor).
My Virtual box settings for MAC was following.
1. Chipset : ICH9
Extended feature : Enable IO APIC
2. Processor : 1 CPU
Extended feature : Enable PAE/NX
3. Acceleration : Enable VT-x / AMD-v
4. Video Memory : 128
Extended feature : Enable 3d Acceleration
Now when I install Mac snow leopard 10.6.2 it says install successful. But when Virtual Box is restarted then it cannot find any active
Boot. plist. [Note that I am using this MAC on Intel Processor]. So please give me solution.
Answered By 10 points N/A #112451
Hello there! Did you take note of the following after installing snow leopard on virtual box?
> If you edited the /Extra/com. Apple. Boot. plist file, you have to install Xcode from the Mac OS X media first.
> Resolution settings for the VirtualBox and on the Mac must match for the screen resolution to take effect.
> Both .com.apple.boot.plist and Custom Video Mode 1 setting should match and are active. Otherwise, the resolution you expected will not work.
> Run the following command from a command shell on the PC side of VirtualBox on the VirtualBox host to enable the resolution: VboxManage setextradata “Mac OS X” “CustomVideoMode 1” “1920x1080x32”
> Add the following properties in the com.apple.Boot.plist file:
Graphics Mode – String – 1920x1080x32
Graphics Enabler – String – y
