Virtual DJ errors when loading a video file
Hello experts!
First up, here's my Windows machine spec:Â Win7 32bit OS with 4GB RAM and Pentium Dual Core (2.66GHz CPU).
My problem is about Virtual DJ 7.Â
I am frequently seeing a warning on the screen every time I load a video file.
Error:
VirtualDJÂ Â Â Â Â Â Â
Decompressing this file in memory would require 516Mb of contiguous      Â
memory.      Â
Your system has only a total of 864Mb available free segments (out of       Â
the 2047Mb), and they are too fragmented to hold a contiguous buffer.      Â
Therefore, the song will be loaded on-the-fly from the drive (and the      Â
full waveform preview will not be available).
Even big or small vob/mpeg file causes this error. If I close down the application, the process goes smoothly. If I don't use Waveform, it loads file and plays it properly. However, it doesn’t cause any effect on dancers part.Â
What can I do to repair/update the application?Â
Can anyone help me?
Thanks in advance.
