Virtual dj problem in laptop
Asked By 7060 points N/A Posted on -
I have installed Virtual DJ v6.0.2 professional on my computer with Windows XP OS. The first time I ran the Virtual DJ in 2 minutes the program closed and I got an error message: Protection error 8. Please contact us on http://www.virtualdj.com/contact/
Answered By 0 points N/A #84915
Hello there,
                     Looks like you're using an illegal version of Virtual DJ. If its an illegal version then you're absolutely helpless, if you've bought it or if  you have requested a demo version then you need to insert your serial number in your profile ad then try. If still the same problem occurs then probably try updating the software and check. Here's the link to get the updated version-
http://www.virtualdj.com/buy/index.html
If still the same problem persists, kindly go to support section or Contact Us page and give them your queries and they'll get back to you with an appropriate answer.
Good Luck!
