Virtual Machine Error on Linux SuSE
I always get an error message when I open the virtual box on openSUSE11.4.
Error
Failed to start vm-install
Details OK
Why do I always get this error?
Error
Details OK
I think this problem is related to basic problems. Sometimes it happens for some programme missing or deleted.This missing happens due to virus, malware spam etc. At first you should uninstall your virtual box.If you have any updated antivirus, then scan your c drive or whole computer. After successful scanning, you install your virtual box. Then open & notice. Although those error has seen, you should try to update your software.If this software is latest, then troubleshoot your computer. If it is not fix then try to set up your whole computer.I think, by the above mentioned way you would be succeed.
