Is the Virtual Machine Images BitNami need installing?
I want to try the Virtual Machine Images program "BitNami". I do not want to install it, because I am not sure if it is really the program that I need. I read that this program doesn't actually need to be installed. Is there any other Virtual Machine Images with this criteria?
Best Answer by shawon
Answered By 0 points N/A #146243
BitNami Virtual Machine Images consists of a simple Linux based operating system and fully configured BitNami application stack.
This helps running the program without installing it on your computer, which is also known as a portable program.
If your computer has virtualization support, you can start using BitNami Virtual Machine Image without installing it, which keeps it separate from all other installed programs on your PC.
Answered By 0 points N/A #146242
 Hello!
BitNami Virtual appliances is VMware virtual machine are fully installed and configured BitNami application Stack.
If you want to run this appliances you need to have virtualization software from VMware already installed,
You can download them at www.VMWare.com
You can log into your computer to stop or restart the servers.
one installed, you 'll be able to run BitNami Virtual Machine Image.
