Virtual Machine Workstation, A Safe Way To Use Your Computer!
A) Well, a virtual machine workstation is simply a machine that is created upon a powerful machine that uses some software to create a virtual space for itself to use it. This machine uses hardware and components that are installed on that machine. And the amount used of these resources can be limited by the user.
It is safe as it not present and installed on your system hard-disk. Also, it does not affect the system that is installed on the machine.
B) A virtual machine workstation could be called a not exiting machine as it is not present inside the machine’s hardware where it is made. And it only uses the resources of the machines that could be pre-determined by the user.
It is safe as, it a machine that creates an overlayer on the actual machine which hides the actual details of the machine and also, it is
Virtual in nature which means it is not real and can be gotten rid of very easily.
