Virtual PC problem in configuration
Hello guys and girls here,
I installed Windows Virtual PC along with Windows XP Mode on my computer having specs of Pentium core I 5 second generation processor with 4 GB RAM running Windows 7.
When I try to configure Windows XP Mode in Windows Virtual PC, following error messages appears.
Windows Virtual PC
Unable to Start Windows Virtual PC because
Hardware-assisted virtualization is disabled
Please follow these steps to enable hardware virtualization:
-Restart the computer and enter BIOS setup.
-Save BIOS setting.
– Power off the computer, wait for few seconds and start the computer.
You can check your computer manufacturer’s manual for details on BIOS settings.
Learn more about BIOS virtualization settings   Â
        Close
I tried to understand and what I got is to go to my bios setup on the pc power on and locate every menu of that, but I cant able to find that hardware virtualization stuff. Is this some sort of hardware add-on or what as my pc is the latest one. Kindly help me to locate, add, and install this hardware based virtualization support as I badly need to run different flavor of Linux and Windows on virtual PC.
