Virtual Rack Addin error has occurred
While working on “Virtual Rack Addin”, I’m getting an error message like the one given in the screenshot. Can you please solve it?
![Data record set Rack Details not found.](https://www.techyv.com/sites/default/files/users/David%20E%20Peterson/Virtual-rack-Addin.jpg)
“Virtual Rack Addin
Data record set Rack Details not found.”
“Virtual Rack Addin
Go to the link below and download the Rack Server Virtualization: A Microsoft Visio Add-In Implementation. It contains all the information needed including the installation and configuration of the Visio Add-In.
Virtual Rack (or vRack) is a tool for isolating servers and setting up a virtual LAN environment for them. The error "Data record set Rack Details not found" appears when the virtualization process of Rack shapes is attempted before the Diagram is generated. To fix this problem, you need to create the Rack Diagram, either by importing one from a Excel worksheet or by making one manually, in the Virtual Rack Wizard.
