Virus on Angry Birds latest instalment
What are the effects of installing the fake version of the Angry Birds game?Â
Will this put me and my data in grave danger?
Dear friend
Fake Angry Birds game app. consists of malware.
If you install this type of application then it will put your data in grave danger.
The effect of malware
Only use application which is authorized by developer.
Hello Patrick,
You should take precaution against installing the fake version of Angry Birds on your computer, and any other Software that you may want to use. Some of the things you will need to do are the following:
But if you can afford a full version I will recommend that you go for it.
Carl
