Ecas Muzia
Posted on - 08/09/2011
In my Office, we have a network on server system. Some big viruses attacked the server and we have virus on all systems which were attached with the server. Can you guide me how we remove the virus? Whether from server or we have to remove from all individual computers?
zobia
Virus in network server system
Hi Ecas,
Well if you try this from safe mode and all the computers have only data shairing then there might be no need to remove the virus from each and every computer but only the shaired folder or drive otherwise you have to do this individually.First of all you have to check that your Anti-virus is registered or not. If not then buy its membership or download the registered one, after registration. Update it to latest version. So it can work accurately. Also make sure that is your computer is compatible for the requirements of Anti-virus, Especially the RAM. After that check that which windows you are using. Try to update the previous or the best thing is that uninstall it and download the new and latest version from a good source and make sure that your system supports the latest version. Other thing is that there might be some file corrupt or some virus is there which is resisting the running of your program so try to scan your computer and repair the windows and other files. Do this in normal mode or the best thing is to do it from safe mode.
Good Day!
