hunter05
Posted on - 10/30/2011
I have a computer and I did install many anti virus programs, but the sad part is they will not protect my computer as promised. What anti-virus software will I use that will destroys the virus and their tracks? And why is it important to have a spyware and anti-virus at the same time? Please provide me the best answer to this questions.
Virus protection software that can protect my computer
Hi Hunter05,
A pleasant day to you. Spyware and anti-virus is very important to be able to protect our computer system into viruses. They have a very big contribution because anti-virus make our computer safe. I don't know what anti-virus you are using right now but I recommend you to install Norton or Avast anti-virus because they are proven to be the best anti-virus software. I have been using Avast for more than two years now and I never had a problem with it. My computer is safe and protected. And I also suggest you to always update your anti-virus once you already installed it. And lastly, you also need to open or activate your system's firewall to be able to completely protect your computer.
-Zorian
Installing a single Anti-Virus is good enough to protect your computer from virus infections and malware bytes. However, this Anti-Virus software must have an updated software installed to fully protect your computer and is operational.
There are numbers of Anti-virus available for download, free and is required for subscriptions.
The best free Anti-virus software available for download are AVG, kaspersky, zone alarm, panda, security essentials from Microsoft and many more.
You can also install Anti-Virus that are not free but also one of the best are the following; Norton, Symantec, CA, McAfee and other Antivirus not known because they don't market there product more but also one of the best.
However, no matter if you have numbers of Anti-virus software installed but you let the Virus come-in, then all are useless. You have to be aware if the software you are downloading contains virus. Most Anti-Virus provide warning if virus is coming but this depends on the user. So, be aware and careful of the software you are using.
lee hung
75 points
Hello Hunter,
It is important that you should have an antivirus program installed on your computer so as to protection your computer from virus attacks and other malware that may cause harm to your system in general. One of the best Antiviruses that I will recommend that you use is AVG internet security. AVG offers you the best protection by detecting any malicious software that may come by using transferrable USB drives; it scans every link that you access on the internet to protect your computer from malicious viruses and Trojans that might attack your computer as a result of downloading files from the internet. AVG also ensures that any program that you might want to install on your system is genuine. Another important feature in AVG is memory usage reporting hence allows you to guard against the system slowing down.
I will not recommend that you install a spyware program on your computer because it may turn out to be harmful by transmitting your private information online, hence exposing you to possible attacks on the internet.
__
Regards
Lee Hung
Hi  Hunter05
Also check out this Techyv YouTube video to get more idea regarding on your issue.
What is Malware? Computer safety tips
