Viruses in Linux and Linux OS
Does Linux affected by viruses but Linux OS are prone attacking by virus?
Are these systems require access installing and run viruses?
First, Linux is not 100% safe. There is no guarantee that it will not affected by the virus. Â The possibility and rate is very low compare to any other operating system.
Since you are curious whether a Linux operating system can be infected by a virus or not, there is a simple answer to that. Why would programmers waste their time creating complicated codes just to infect an operating system that is less used?
The real purpose why a virus is created is to spread to as many users as possible to any location using any kind of media.
And then acquire vital personal information. If a virus would infect a system running Linux, the range of infection would be very less compared to Microsoft Windows and not much information will be collected so what’s the use. Besides this fact, the Linux source code is freely available allowing different users and developers to get their hand on the code.
So if this is the case, coders will really not make any attempt to infect it since they can even insert their own code to the operating system that easily. Even if Linux is very less targeted by viruses, this operating system can then again store Microsoft Windows virus executables without getting itself infected.
