Vision Assistant 8.6 Support Image Acquisition from My Smart Camera
Hi there,
I just installed Vision Assistant 8.6 and I have this error. This is not the first error that appears but I would like to know if the program supports image acquisition from my smart camera. Does anyone knows if it supports image acquisition ? How can I find this ?
Thank you !
No Remote System Found.
No compatible remote system on your local subnet were found.
Select Refresh if you want to search again for remote system on your local subnet.
Select ADD Target to add a remote system that is not on your local subnet.
Select Cancel to continue using the same remote system.
