Vista Local Access Problem Only.
Few weeks ago I became the owner for HP Pavilion dv6000 as I own it and it is installed with the Vista Home Premium and I have some trouble working with wireless connections. As I worked once for some span of time and decided to stop but with an Ethernet cable Internet is working fine and using wireless.
Saying that it is just connected and have local access and with both Ethernet and wireless it is showing that you are being connected to multiple networks and is not connecting to the single network.
Even there is an availability of multiple networks and even diagnosing also the problem is not rectified and checked other system. It is working fine and with same signal I am unable to connect so kindly help me in fixing this issue.
Thank You.
