Hello Guys! I installed Vista Pre-RC1, but I got this error. I searched the error code through internet but no luck.
Will you please guys let me know where I can find a solution or much better if you can give me the solution about this error?
Freeway (CCRF) Alpha 4
Run-time error ‘339’:
Component ‘mswebdvd.dll’ or one of its dependencies not correctly registered: a file is missing or invalid
Vista Pre RC1 Error message
Howdy Joshua,
That kind of error occurs because of the dependencies which are not properly or correctly registered or due to a missing or invalid file. Try to reinstall. It might help.
Restart or reboot your computer
Restart the latest version
Update the drivers for your video card. For more information, please visit this link.
Follow the step by step instructions to be able to solve your problem. I hope it might help. Let me know if it will work and do not hesitate to message me if something goes wrongs. I'll be glad to help you out.
-Zorian
First thing you do is you must check the installer if there an corrupted file and then try this you just simply repair from the CD installer you just simply reboot your PC then try restart you PC and then insert the CD installer you or CD-ROM and then just press the F2 from your keyboard and then just select the repair tool or maybe you just simply download the error repair tools and then simply install that to your PC and then after you install the software you just simply start scan your PC and after you scan the software just simply repair the found errors to your software.Â
Ben
