Vista upgrade hangs at 62%
Asked By 7060 points N/A Posted on -
I have a laptop Acer 5320. The original window of system was window vista. Now, i want to install new window on my system (window 7). But i am facing problem during installation that Window upgrade hangs forever at 62%.
I am tired with this problem.
Please help me with this problem.
Thanks
Best Answer by kennethk
Answered By 0 points N/A #80052
This problem normally occurs when the Iphlpsvc service stops responding during the upgrade although other services may also cause a problem in which the upgrade process stops responding. To fix this problem, follow the following steps.
  • Restart your laptop. Your computer will roll back to Windows vista.
  • On the start menu, right click computer and then click properties.
  • On the advanced tab, click environment variables.
  • Under system variables, click new.
  • Type MIG_UPGRADE_IGNORE_PLUGINS in the variable name field.
  • Type IphlpsvcMigPlugin.dll in the variable name field.
  • Click OK on the three open windows.
  • You can now start the windows 7 upgrade process.
Answered By 75 points N/A #80053
It is one of the problem in the new PC.  If you want to install  Windows 7, then you have to have a high processor computer. I think your computer meets the requirement.  To install follow these steps:
  • Restart your laptop. Your computer will roll back to Windows Vista.
  • You can now start the windows 7 upgrade process, then you can get the full install windows 7 XP.
