Vista Windows Movie Maker keeps on crashing
I am editing some videos using the Windows Movie Maker on Vista. There haven’t been any errors until just recently.
I would now get an error whenever I import a video clip.
The error even appears when I use videos that have worked previously.
The application has an option to disable video filters in case of issues with compatibility. I even disabled other players and video editors, such as Nero, QuickTime and DivX, just to have Windows Movie Maker use all the necessary files needed. Unfortunately, doing that did not change a thing. Now, the application cannot be used since it has completely malfunctioned.
Error:
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.Â
Any of your suggestions are acknowledged and will be tried.
Error
Microsoft Excel
Microsoft Excel has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Close progtam
Thanks in advance.
