Visual basic 2010 shows error
Installed perfectly my VB 2010 express but after a few weeks this error is always appearing whenever I open VB and now I can't continue on my project. Any help would be appreciated!
Microsoft Visual Basic 2010 Express
The operation could not be completed.
Answered By 10 points N/A #147756
Hello Donal,
Here are things that you should try in order to resolve that issue:
  • Completely uninstall and then reinstall the VB application.
  • You could also try restarting your computer a number of times and see if that will resolve the issue.
  • Try running the application as the administrator.
  • Also try running the application in compatibility mode.
  • You should try checking for updates using the Windows Updates for both before and after the installation
  • Try uninstalling all .NET Frameworks, the Visual C++ redistributables as well as updates Programs and Features, and then run Windows Update to get the latest version of everything. After that reinstall Visual Basic 2010 Express.
Carl
