Visual basic codes to create a program for food recipes
I am asked to make a program about a grocery shop for food recipes, and I need some sample codes for this so that I will be able to revise in my own.
Just a reference, and video tutorials will help as well. If you do know some links and information.
Let me know about it.
Have a nice day Experts.
Best Answer by Fraserr thor
Answered By 0 points N/A #150198
Hello Gran,
There are lots of sample codes you can choose from.
There are sites that can freely give some sample codes of their past projects.
But I have to give one. Here is the link:
Also try programmersheaven.com
Hope it will help.
HTH
Answered By 0 points N/A #150199
Visual Basic is made for making programming easier.
It contains a complete graphic development tool to make programming easier.
Take a look in Microsoft website to find out Visual Basic tutorials.
Learn more about VB Programming language and make a program of your own.
It will help you to improve your skill at VB Programming language.
You have made a program of your own.
So run the program and see if everything is ok.
If doesn’t run properly, then revise it and find out defect.
Search on the web and you will find a lot of sites where you can get samples of your program codes.
1. Yiola
2. Dannon recipe box
These are programs which were made using VB Programming language.
