Visual Basic Portable Database Problem
Good evening.
Ive been doing some self study on VB Programming this past few months and I have this Visual Basic Portable installed in my computer to practice on. This software was actually given from my friend and when I was about to create a database, there was this prompt message stating I cant create one because there is a file missing.
What would be the cause of this error and what is that file containing the database.?
Answered By 0 points N/A #100664
Hello there, your not specific on what kind of problem you encounter but basically you need to reinstall your software application on BV so that you can use all the needed features in order to make your own database.In order to do that the basic portable software applications should be updated you should check on the website where your friends got the software so that you will know if its still applicable on the works that your do, or if there is a need to purchase a new version to make it works for you.
Some people they tend to forgot that the software applications is continuously evolving meaning everyday ist upgrading and new features is added on your software programs and if you are not aware of it, you will be left behind or your software program will become obsolete,that is why you need to follow updates and download the necessary add ons for your computer software applications.
