Visual C++ Runtime error Opera Next
Hello TechyV buddies!
I am having some problem with runtime. Whenever I try to open opera and shuts it down, an error message pops out.
The error is this:
Microsoft Visual C++ Runtime error
R6025
program:C:program filesOpera NextOpera.exe Pure virtual function call
Can anyone help figure this one out?
I really need here on this issue.
Thank you!
Answered By 0 points N/A #147933
hello there Centric. Visual C++ runtime error occurs when you have an old version of visual c++ and then you try to launch a program that is using the updated visual c++. to solve this problem you should install all the new updates from Microsoft. or the other option is go to run command. type run , >> a window will appear. >> then look for the services tab. >> click hide all Microsoft services. then disable all. and restart your computer. this will solve your problem. have a nice day
