I drew a text box using visual designer. I inserted a text in the text box and it looks okay but when I preview the page the text appears on two lines it’s like the text being compressed  by the text box. This means the text is small for the text. I enlarged the text box and made it big but it still the text cannot fit in. the text is paragraph title how do I fix this?
Visual designer preview problems, please help?
First you need to see if the text that you are entering is of large font size or not. Sometimes, the visual designer uses a bigger font and it does not fit in the text box. This can also be due to your browsers settings or your computer settings but make sure you check the font size.
After that, set the height and width of the textbox in the code. Make it double it if it troubling too much.
Sometimes using a large message box can also solve the problem. You should give it a try too. But if you follow the above steps, I am sure that it will solve the problem.
