Hello Techyv Users,
I need to have a Visual Lightbox that works on iPad, Is that possible. If anyone has already used or have Visual Lightbox on the iPad, Please guide me about, where to download and how to use it. Will it work with all iPads, or is there any specification, Waiting for a reply.
Thanks & Regards,
Margaret M Griggs
Hello Margaret,
I have been using iPad for almost 1 year now and Visual Lightbox which I prefer the most is iLightbox. Trust me you would not come across any other Visual LightBox which is so easy to use and at the same time provides so many functionalities.
There are lots of tutorials available on YouTube which you can watch to have a good understanding of how to use it and its features.
It will work on all the iPad's and all other specifications are provided on below mentioned web site.
You can download it from the link.
