Visual Studio error message while opening a SQL Database
I own a small business office and deal a lot with SQL servers and exchange servers. I get the following error when I try to use Microsoft Visual Studio 2005 Service Pack 1 design tools to open a database connection with Microsoft SQL Server 2008.
This server version is not supported. Only servers up to Microsoft SQL Server 2005 are supported.
I have it installed on Windows Server 2003 R2 (32-Bit x86). There are no other previous installations of Microsoft Visual Studio on this machine. I tried searching in the websites and found it could be because of the previous versions DB which is not a possibility in this case.
There are no errors when I try to open the DB and do modifications, but the moment I click on OK I get the above error message.
Does Microsoft SQL Server 2008 support MS visual studio 2005?
