Visual Studio11 Developer Preview Installation Issue
Hi!
An error message keeps on appearing on my screen while trying to install Visual studio11 Developer Preview.
I have tried to install it directly from internet and downloaded suit yet the same error occurred.
The system cannot find the path specified.
Please help me on this issue.
Thanks
Error:
Visual Studio 11
Setup Failed!
Install cannot continue because some required components failed.
Please correct the following problems and restart the setup to ensure full product functionality.
Type Package Name Error Description
ApplyComplete The system cannot find the path specified.
Close
Answered By 590495 points N/A #159995
Since installing this application keeps on failing, you should check again if it is compatible with your operating system or not.
To review the system specifications of Microsoft Visual Studio 11 Developer Preview 32-bit and 64-bit, read and understand the following details.
Microsoft Visual Studio 11 Developer Preview 32-bit and 64-bit supports Windows Server 2008 R2 64-bit, Windows 7 32-bit and 64-bit, Windows 8 32-bit and 64-bit, and Windows Server Developer Preview 64-bit operating systems.
Check your operating system if it’s included on the list above. If it’s not then this is what’s causing the problem in your installation, your operating system is not compatible to run this program.
To make this application work, your computer should be running on one of the operating systems mentioned above.
