VisualBoyAdvance.exe bad Image or problems downloading VBA
For a while I’ve had problems downloading VBA. Not much to the problem to tell, as I know nothing of it. This is what happens when I try to open it. Any idea what the problem is and how I can fix it?
Thank you !
VisualBoyAdvance.exe – Bad Image
Answered By 0 points N/A #181803
"Visual Boy Advance" is a Gameboy and Gameboy Color emulator for PCs. The only version of Visual Boy Advance is 32-bit, which means that it may run into compatibility issues if run on a 64-bit system, such as Windows 7.
To fix this problem, right click on VisualBoyAdvance.exe, click "Properties", click "Compatibility", check the box next to "Run this program in compatibility mode for:" and select "Windows XP Service Pack 3" from the dropdown menu. Also check the box next to "Run this program as administrator".
Click OK and now you can run your Gameboy emulator.
