What are the distinct and significant features of WhatsApp Plus and that of the WhatsApp? What do these software applications share in common and which of the two you prefer or recommend? I have a couple of friends who are using WhatsApp Plus and WhatsApp and every time I do ask them why they are using such preferred application they seem not to give me a satisfied answer and so I do plead for your assistance. Lydia Sam is my name from South Africa. I am 15 years old. Thank you.
The vital features differentiating between WhatsApp and WhatsApp Plus
Hi Mildred,
The difference between WhatsApp and WhatsApp plus is there in terms of look only. The operation in both the apps are same, there is no difference between this two apps if you are looking at those in in operational view.
But if you are a design lover then WhatsApp plus can be a good option for you. Since the new app has over 700 visual theme through which you can totally change the look of the app.
If you are a looking for more fun in chat then a lot of new emoticons are also present on the new app for you. Also you can edit appearance and settings of almost everything in the app that makes it look different from the traditional app. By operation both this app has chat, pic sharing, video sharing, and voice message sharing option.
Now for a outlook lover or design lover person, WhatsApp plus will be a great option and recommended for its customized look, but for operational people who are using WhatsApp for work traditional app is better and recommended.
Derick Harris
