What are some of the fascinating and still considered as vital features of the HP Spectre x360 machine? What makes this HP Spectre x360 gadget so special from other brands of similar kind? What are the pros and cons of using the HP Spectre x360? Can the HP Spectre x360be considered as the best collaboration design so far considering other brand designs?
The Vital Features Of The HP Spectre X360
Hello Raymond,
The HP Spectre x360 machine was developed by the HP Company partnering with Microsoft. The HP Spectre x360 comes with an enhanced battery life and more reliable performance. Comparing the HP Spectre x360 to portable information processing systems that are SSD-based, it boots so fast as if the machine is resuming from sleep. The HP Spectre x360 laptop like other Ultra books, is a U series ULV 15 watt CPUs with 13” to 15” thin and also light in weight.
The chilling of the machine besides fan noise are controlled devoid by the disproportionate amount of heat throttling as the fan is correctly put. Although the sound of the fan can be heard when playing a 3D game for example, it makes no serious worry. The same HP Spectre x360 operates on Intel Broadwell 5th generation Intel Core i5 and i7 Central Procession Unit. Besides, it comes with either 4 or 8 Gigs of RAM with SSD sizes between 128 and 512 Gig.
The charging port of HP Spectre x360 uses a smaller size HP charger. It uses a smaller port of 4.5mm at 45W which is situated along the back right side of the laptop. The charging light indicates orange and turns white when fully loaded. The three USB 3.0 ports of HP Spectre x360 are located one on the left side and two on the right.
Looking at the keyboard and the touchpad of HP Spectre x360, the keys are spaced out well thus making typing convenient and with views to the touchpad, two finger scrolling and pinching to zoom in or out among others materializes smoothly. Like on the Mac, one can right-click by tapping with two fingers on the touchpad.
One fascinating feature about the HP Spectre x360 is the backlighting key that continues to set alight when you detect a gloomier in the working area and then you can access and see the backlight key. When working on a 1080p video streaming project and also a casual 1080p video editing and export, MS Office, Photoshop, software coding for institutional organisations, the HP Spectre x360 come handy with an Intel HD of 5500 graphics.
These among others are what you should expect from HP Spectre x360 as compared to 2015 Dell XPS 13, Microsoft Surface Pro 3, Lenovo ThinkPad Yoga 12 (2nd gen), non-touch full HD Dell XPS 13 and 13" Retina MacBook Pro among others. In a close, anyone who adds up into contact with HP Spectre x360 machine tends to appreciate its efficiency and its keen design. With its full HD display, is amply noble for serious photo editing, and you do not have to remunerate more for a touch screen in addition to pen support.
Brenda Cruise
