VLC error opening after installing due to missing DLL files
I just installed VLC Player on my PC with Windows XP and I have this error when I want to open the software. The installer is for Windows XP (x32) and I expected that will work. Any solution ? What is causing this one ?
Thank you !
Vlc.exe – Entry Point Not Found
The procedure entry point_vlc_thread_ready could not be located in the dynamic link library libvlccore.dll.
