Hello there,
This morning VLC Player was closed by this error. I don’t know what caused this or how can this be solved. To problem is that it started to appear more often. Can anyone help me please to fix this error ? What is causing this ?
Thank you !
Vlc.exe – Entry Not Found
The procedure entry point_vlc_thread_ready could not be located in the dynamic link library libvlccore.dll.
OK
points
VLC launching error due to missing DLL files
VLC Media Player runs with its built-in codecs and system core files. The entry point was required to acquire the power of running properly. As it was failed, it couldn’t run perfectly and threw up the error.
In order to fix this issue, you have to uninstall the existing installation of your VLC and then install the latest one as it comes with more stability and performance fixes. Download VLC Media Player.
Now, run it again and then try to play any media. It should go fine without popping up any more error.
