In the process of network streaming, when I input the URL on the song that needed to be streamed, I receive the following error message. “VLC media player just crashed. Do you want to send a bug report to the developer’s team?" I have reported this to the team but no one helped. What do I do now?
VLC Media Player Crashed when Streaming Network
Rt
Sometimes back, we started getting the same error on one of our workstations, running on WIN 7, 64 Bit.
After working on multiple solutions to trace out the reason for this error, we found that working with the following one or both the suggestions do repair the error. Actually sometimes it happens that the VLC config and caches files gets corrupted, resulting with this error.
1- Go to the following path c:Documents and Settings<username>Application Datavlc directory, (where C is the partition where the VLC is installed) and search and delete the “plugins-04041e.dat” file. Then try to start the VLC player
2- Simply click on start and type RUN on search file and folders, press enter.
On Run.exe type” type %appdata%vlc” and delete the folder.
Now start the VLC player, it should start without any error.
PT
To solve this issue delete VLC preferences and cache. To do that go Start Menu>>All programs>>Video LAN>>Reset VLC media player preferences and cache files. Go this Techyv page because there you will get few new idea to resolve this issue.
VLC constantly crashing and showing error message
