VLC player for Android mobiles
Is it true VLC has launched its release for even Android mobiles. Does VLC support for IOS ? Where can I download this new software for my mobile ?
Dear Chris J Curry, I have read your query.
Yes you are right, VideoLAN Organization have launched their 2 VLC media applications, which are VLC Beta (NEON Version) and VLC Direct Pro Free. All media formats can be played just like a PC Version. There is also network support. When playing a video, a separate file for audio and or subtitles can be played instead of embedded one, just like the PC version. It is in Beta state and mostly for the use of intruders so one should use at his own risk. Pro version is comparably stable and with free Pro features for the time being. Here is the link for the download page:
 https://play.google.com/store/search?q=VLC+Mobile+Team
About iOS, there is also a version for iOS, but a different one compared to the classic version. It uses same plugins but slightly different interface. Video LAN Organization do not provide a binary package at the movement, instead there is source code for iOS version. Here are links for source code:
http://download.videolan.org/pub/videolan/vlc-iOS/1.1.0/MediaLibraryKit-1.1.0.zip
http://download.videolan.org/pub/videolan/vlc-iOS/1.1.0/VLC-1.1.0-iOS.tar.bz2
http://download.videolan.org/pub/videolan/vlc-iOS/2.0.2/vlc-iOS-2.0.2.tar.gz
Hope it helped.
The VLC media player supports many different operating systems like Microsoft Windows, Mac OS X, and Linux. Aside from these 3 operating systems, VLC media player also supports FreeBSD, NetBSD, OpenBSD, Solaris, and more. For mobile devices, both Android and iOS are supported. For Android users, download it from Google Play: VLC for Android. Please be reminded that VLC media player for Android devices is still under heavy development.
The latest version is VLC media player 1.6.6. For iOS users, download it from the Apple App Store: VLC for iOS. Your Apple device should have iOS 6.1 or higher to be able to run VLC media player. It supports iPhone, iPad, and iPod touch. The latest version is VLC media player 2.6.6. For computer users with Microsoft Windows, you can download the latest version from VLC for Windows.
The latest version for Microsoft Windows is VLC media player 2.2.1. For computer users with Mac OS X, you can download the latest version from VLC for Mac OS X. The latest version for Mac OS X is also VLC media player 2.2.1. It requires Mac OS X 10.6 Snow Leopard or higher.
