dinacallway
1220 points
Posted on - 07/11/2011
Hi friends, last night,I downloaded a movie from the internet, after the download was finished, I want to watch the movie using Vlc player, and error occurred when I start the application, I posted below the screen shot.
Vlc.exe – Entry Point Not Found
The procedure entry point_vlc_thread_ready could not be located in the dynamic link library libvlccore.dl
I keep on trying to run VLC player but same error was displayed, I even restarted my computer and run VLC player again, same error was displayed, I remove and re install VLC player, same error was displayed, on my last idea in solving my problem, I scan my computer for some virus, but no virus was found, I don't have an idea now in solving this issue, please help me fix my problem, many thanks in advance.
VLC player Entry Point Not Found
In your question, you haven't mentioned the version of the VLC player that you are using.
Things you can do to fix this problem are:
Check if you have completely installed your VLC player. If not, then re-install it.
If installation is complete and the error still occurs, then check your system registry. It might be that your registry is damaged. Try to clean your registry. You can use some registry cleaner softwares you can download (google it).
Try to install VLC Media Player 0.9.3/0.9.4.
Seems like your VLC media player has a problem with one of its DLL files the “libvlccore.dll” file. This DLL file is located in VLC media player’s installation folder which is “C:Program FilesVideoLANVLC”. If the file is in error, it means VLC media player cannot access it because it is damaged or corrupt. To fix the problem, just reinstall VLC media player if you still have its installer.
Or just download and install the latest version from Download VLC. If you already uninstalled and reinstalled VLC media player and it still doesn’t work, there are probably some leftovers that cause the program to fail. Before installing the latest version, download Revo Uninstaller Freeware and unpack the file with 7-Zip. Use the supplied password to unpack.
Next, install Revo Uninstaller and use it to uninstall VLC media player. After removing VLC media player, go to CCleaner Free Download then download and install the latest CCleaner. Once installed, start CCleaner and clean your system. Restart your computer afterwards. After this, install the latest version of VLC media player and see if this works. To register CCleaner, download CCleaner Registration Codes.
Use the supplied password to unpack. Open “license-keys_readme.txt” with Notepad and follow the instructions to register CCleaner.
