Robert Jone
Posted on - 11/23/2011
I installed VM ware to my Fedora14_x64and the installation run smoothly and installed successfully.
But after the installation, I run VMware and error appeared. Please help me about this problem.
You can help others to by sending us the solution.
Error
Unable to build kernel module.
See log file /tmp/vmware-root/setup-7357.log for details.
Rogers U
10 points
VM ware Installation error message.
Robert Jone
I also faced this issue sometimes back, and was lucky to find the solution, with the help of a friend.
The solution is provided below:
1. Go to the url:
2. Download the file named as “patch-modules.sh”, and save it to someplace like “temp” folder
3. Now you need to change the permission on the file, as such use the following command:
root@Ri temp# chmod +x patch-modules.sh
4. Now you need to execute this file, as such use the command:
root@Ri temp# ./patch-modules.sh
5. You have to wait patiently, and you will be informed when the command completes, and you will be able to launch / run the VM Player smoothly
Rogers
