VMC Mobile connection not possible
I have a Huawei E160X on PAYG. It performs excellent in the UK with United Kingdom Cellular Hook up En aning 9.3.5.11690.
I went to the country and removed the UK VMC application before linking a Huawei K3770 usb hub which set up United Kingdom Cellular Hook up 10.2.102 30707.
Every time I tried in order to attach with the Spanish hub I obtained the Mistake Value 631.
Returning in UK I tried my UK hub it, furthermore was incapable in order to attach using VMC v10. I got the same error concept I got in the country although the code was 720.
I tried all the recommendations involved in the error notification box without achievements. I had to remove VMC V.10 and return to edition 9.
Just to get it work again. I wonder if there is an issue between the two gadgets due to the uninstaller making behind some configurations. Can any of you provide me a suggestion about this?Â
I'm completely confused. I attached below the error notification for the ease of your understanding.
Error:
Mobile connection not possible.
-set your current mobile as the default device under the device tab in the advanced window
-Ensure that no other application are using your mobile device and try again in a short while
-Delete the device under the 'device'tab in the advanced window,add it back again,and try connecting
-If you see the Account type option in the option window, check that the right account is selected for your sim.
If this error persists,please contact Support at your mobile network operator.
Support information:
RAS error cod 720
Did any of you face this problem before? If yes, then please share your experience and suggestions. I would be very grateful to you.
