I.sancho
Posted on - 06/27/2016
Hi. I have been trying to connect to the virtual machine but repeatedly failing. Also, the VMRC session is opening with the vSphere web client but not with the vSphere client. Every time the following error is being shown on the screen: VMRC console has disconnected. Attempting to reconnect. Can you please help me with the same?
VMRC Console To Disconnected Error: Try Connect To Virtual Machine Console Fails
Hi. VMRC console has disconnected an error which generally comes up because of an antivirus software which blocks certain functionalities of the software installed on client/server systems. To work out the issue –
1) In the antivirus software, disable application control for virtual applications.
2) First, uninstall and then again install the vSphere client.
3) From the Windows Task Manager, vmware-vmrc.exe*32 should be stopped after which the user should log in again.
You can try either of the above three solutions. Do reply in case it still does not work.
